Activity Forums Boris FX Particle Illusion Can´t get image sequence from PI 3.0.1
  • Can´t get image sequence from PI 3.0.1
    Posted by Damian Fernandez on July 2, 2009 at 11:02 pm
    I use this many times but now seems like only work for output on avi, not image in any format, program seems like making the proces but on output folder is nothing…what i do wrong, or maybe is some software i install and get problems with PI? Thanks.
    Alan Lorence replied 17 years, 2 months ago 2 Members · 1 Reply
  • Alan Lorence
    July 3, 2009 at 3:07 pm
    You may be missing the image support DLLs in the particleIllusion folder. Can you load images into a layer?
    If not, then you need to reinstall.
    Alan.
    http://www.wondertouch.com
