Activity › Forums › Apple Final Cut Pro › Can\’t view more than 2 angles in multicam viewer in FCP X
  • Matt Galuszewski
    June 14, 2014 at 11:46 pm
    Rob,
    Do you have the ability to select the event in and then choose FILE > Export Event XM?. I will be able to import that XML
    I can’t remember if that was in 10.0.8
  • Jeremy Garchow
    June 15, 2014 at 12:54 am
    Hey, Rob. Thanks for posting the Event, and thanks, Matt, for suggesting it.
    I was able to update it to 10.1 and the angles show up perfectly.
    Here’s a pic:
    I think that this problem is localized to you machine. I would make a new user and see if the problem persists. When you updated to Mavericks, was it a clean install?
    There’s good info on how to do that here:
    https://support.apple.com/kb/TS4053?viewlocale=en_US&locale=en_US
    Jeremy
  • Matt Galuszewski
    June 15, 2014 at 1:28 am
    Jeremy,
    How did you update the event? FCP here won’t allow me.
  • Jeremy Garchow
    June 15, 2014 at 2:16 am
    It’s a bit of a trick.
    If you have the Event on an external drive, make a folder called “Final Cut Events” on root level of the external drive.
    If using your boot drive, put the “Final Cut Events” folder in your user > movies folder.
    If you already have a final cut events folder in any of those locations, temporarily move any other folders out of it to prevent unnecessary updating to libraries.
    Inside the final cut events folder make a new folder and name it whatever. I named it RobDavis.
    In the ‘RobDavis’ folder, put the unzipped downloaded Event and rename it to “CurrentVersion.fcpevent”.
    In fcp, choose File > Update Projects and Events.
    And then choose the external drive under “locate” or choose update all if the event is on your boot drive.
    The Event should update.
  • Rob Davis
    June 15, 2014 at 2:36 am
    Bingo! I opened the project under a differnt user account and it opened right up in 4-angle mode. I never would have thought to try that. Thanks so much to everyone!
    I was just about to update to Mavericks but I’m currently putting the finishing touches on a feature documtary in FCP7 and I don’t want to risk having to deal with problems after updating. I don’t know what I’d do without the cow!
  • Matt Galuszewski
    June 15, 2014 at 3:21 am
    Thanks for that. I had done everything except make the sub folder under the Final Cut Events folder. How quickly one forgets the way it used to work.
Page 3 of 3
