Activity Forums Adobe After Effects Can you zoom past 800% in comp window?
  • Can you zoom past 800% in comp window?
    Posted by Anthony Sneed on April 29, 2020 at 7:04 am
    I’ve always wanted to know if you could zoom in past 800% in the comp window. I see that there are more options such as 1600%, 3200% 6400% but they’re greyed out. Anyone know how to access these?
    I’ve uploaded a pic of what it looks like for me.
    Viliam Snag replied 3 years, 2 months ago 4 Members · 3 Replies
  • Walter Soyka
    April 29, 2020 at 2:14 pm
    The zoom level is dependent on the size of the comp. Larger comps cannot be zoomed as much as smaller ones.
    There’s probably a maximum size for the CompSize * Zoom; it seems to be 32,000 pixels in any one dimension. (In other words, you can do a comp 7999 pixels wide at 400%, but not a comp 8000 pixels wide).
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Chris Orcfilm
    May 22, 2022 at 3:09 am
    I know this is an old thread but in case anyone still has this issue, especially as we have to deal with higher and higher resolutions, depending on the complexity of your comp, try this:
    1) File > Scripts > Scale Composition.jsx
    2) Chose New Scale factor of .5 (or .25) [Scale]
    Now you should be able to zoom in farther. When done, repeat Steps 1-2 but choose a scale factor of 2.0 (or 4.0) to reverse everything.
    Hope this helps!
  • Viliam Snag
    July 4, 2023 at 8:09 pm
    Hi Chris, I tried your suggestion but even though it did increase the percentage the actual zoom amount visible on the screen was still the same. I’m working with 8K footage and need to cut out some stuff and with zoom in AE maxed out at 200% it just wasn’t close enough. I figure out that if you open it in mocha you can zoom in all the way regardless of resolution and can save it as a mask so win win!
