Activity Forums Maxon Cinema 4D Can you use the C1/C2/R1/R2 selection tags on a tube object?
  • Can you use the C1/C2/R1/R2 selection tags on a tube object?
    Posted by Jennifer Kahn on December 23, 2008 at 4:46 pm
    So I know you can type C1/C2 or R1/R2 under “selection” on the material of an extrude NURBS and have the material show up on just the cap or the rounding part–but when I try doing that to materials applied to a tube object, it doesn’t work. Why is this happening? Can you only use those tags for NURBS objects? Any solutions on how I can texture a tube in a similar easy way?
    Jen
    Brian Jones replied 9 years, 11 months ago 6 Members · 7 Replies
  • 7 Replies
  • Adam Trachtenberg
    December 23, 2008 at 5:29 pm
    Unfortunately the caps/rounding thing doesn’t work with primitives. You’ll have to make it editable. Then you can select the top polygons and run Selection>Set Selection. That will create a polygon selection tag. Select your material tag and drag the selection tag into the Selection box.
  • Jennifer Kahn
    December 23, 2008 at 10:59 pm
    Ah… I see. Thanks for the explanation!
  • Jan Vork
    April 15, 2015 at 3:01 pm
  • Brian Jones
    April 15, 2015 at 3:39 pm
    if you need to keep it a primitive you can use the Correction Deformer trick to set a selection for the tube and use that for your selection. (as long as you don’t change the number of polys in the rounding or caps after)
  • Ben Trahair
    April 28, 2016 at 6:15 am
    That correction deformer trick is absolutely amazing!!
    http://www.bentrahair.com
  • Bcordova
    September 13, 2016 at 10:14 pm
    I was able to use the correction deformer to select fillet cap on a tube(parametric). But after creating/adding selection tag to material selection nothing happened. Any ideas? Thanks.
  • Brian Jones
    September 14, 2016 at 12:22 am
    move the Selection tag from the Correction Deformer to the Tube and it should work
