Activity › Forums › Apple Final Cut Pro › Can You Use “Blade Tool” on Motion Title Clips (.moti)
  • Can You Use “Blade Tool” on Motion Title Clips (.moti)
    Posted by Steve Crow on March 29, 2020 at 2:30 am
    It’s been years since I tried to do any serious editing of purchased Motion title (from MotionVFX if that matters) inside FCPX but I remember the pain I experienced in trying to end a title sequence early.
    The Blade Tool doesn’t work and dragging the end point in to the left only speeds up the title. I remember there was some kind of simple workaround but that information has gotten lost in my brain. Today the only thing I could come up with was to export the title sequence as its own clip, and then re-import that clip into my media library and drag that exported clip onto my timeline. But I know that’s a hack….what’s the better way?
    Steve Crow
    UPDATE: A MINUTE OR TWO AFTER MY INITIAL POSTING I FOUND AN OLD POST FROM THIS FORUM REMINDING ME THAT I CAN SHORTEN, NOT LENGTHEN, A TITLE CLIP BY TURNING IT INTO A COMPOUND CLIP AND THEN I CAN EASILY DRAG THE END TO THE LEFT PERFECTLY
    Brett Sherman replied 6 years, 5 months ago 2 Members · 1 Reply
  • Brett Sherman
    March 31, 2020 at 5:08 pm
    You can just compound the clip. Select the clip then Opt+G to compound it. Then trim to your hearts content.
    When you blade a motion title it sets the new out point where you bladed. And whatever animation you have in the motion template gets scaled to the new clip length.
