Activity › Forums › Blackmagic Design › Can you use Aja Codecs on a machine using a Blackmagic card?
  • Can you use Aja Codecs on a machine using a Blackmagic card?
    Posted by Sean Meredith on February 26, 2006 at 10:50 pm
    I use a Blackmagic Decklink HD Pro (single link) card with a G5. I have a film that’s being color corrected with a KONA card at 1080p23.98 10-bit 4:4:4 RGB. I want to be able to use the master Quicktime file of the project to make trailers. Can you install the Aja codecs on a machine running a Blackmagic card? Will it create any conflicts?
    Sean Meredith
    “Dante’s Inferno”
    Sean Meredith replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
