Can you turn off / switch off a track matte or trim path effect after you’ve finished using it
Hi there,
Would really appreciate some expert help here. I’ve got myself a bit stumped!…
I’m animating some ai illustrations that use outlines that have an irregular line width applied.
Creating a new shape & stroke that follows the irregular line & using the trim path effect set to ‘Alpha Matte’ works really well to animate the lines in in a dynamic way. But what do I do if I then want to animate the ai layer afterwards? At the moment the trim path & track matte means that the layer disappears if I move it away from the trim path shape. Is there any way I can switch of these off after the animate in stage is finished?
Sorry if I haven’t explained myself very well. One practical example is I have the arm of a character that looks like it draws on with the trim path effect, but I then need to move that arm. Hope that makes sense? Any help very much appreciated!
