Activity › Forums › Adobe Premiere Pro › can you trim numerically in a PP CS6 timeline on a laptop???
  • can you trim numerically in a PP CS6 timeline on a laptop???
    Posted by Nick Natteau on December 26, 2012 at 3:13 pm
    Normally you would use the numeric keypad to trim numerically in any Premiere Pro timeline.
    But if you have a laptop (with no numeric keypad) like a macbook pro, is it possible to trim numerically in the timeline?
    Ryan Aqu replied 11 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Angelo Lorenzo
    December 26, 2012 at 6:54 pm
    I don’t believe so, unless you:
    1. Can find a separate keyboard utility that will make your top row keystrokes mimic a numpad
    2. Get a USB number pad (these run about $10 and you can find them in office suppy stores, Best Buy-type stores, etc).
    3. Learn to use the function key. The right hand side of the keyboard also functions as a numpad with + and – being on the : and ? keys. Unless the newer macbook pros don’t use this.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Nick Natteau
    December 26, 2012 at 9:42 pm
    Hi Angelo and thank you for replying.
    Actually none of the macbook pros have numerical pads. I believe”s it’s only PC laptops that have them.
    Regaridng your third suggestion, using the function key, how do you have it configured?
  • Angelo Lorenzo
    December 26, 2012 at 10:10 pm
    I have a 2006/07 MBP and the numpad is part of the traditional keyboard, accessed by holding down the function key (fn key). This is what I’m talking about when I say they have the numpad.
    The keys used will have additional very small numerals on them, and on my MBP include 7, 8, 9, 0, -, u, i, o, p, j, k, l, ;, m, period, and /
    Take a closer look, although I wouldn’t be surprised if Apple nixed it.
    Angelo Lorenzo
  • Nick Natteau
    December 27, 2012 at 1:26 am
    Hi Angelo,
    Thanks for your continued help. Unfortunately I don’t get the same results when pressing the function key.
    If I press “fn +10″, it doesn’t advance me 10 frames on my macbook pro retina (15” model (2011)).
    So perhaps Apple did away with that feature on macbooks.
    Thanks again.
  • John-michael Seng-wheeler
    January 4, 2013 at 5:12 am
    My MBP doesn’t have little numbers on the keys but it does work.
    typing fn +10 isn’t going to work… if you want ten frames you need to type fn+j (which will type a 1) and fn+m (the 0)
    The first in each pair is the numpad key, the second is the key you hit alongside the fn key to produce it.
    1=j 2=k 3=l
    4=u 5=i 6=o
    7=7 8=8 9=9
    0=m +=/ -=;
    Also, “=” is fn+-
  • Ryan Aqu
    December 16, 2014 at 8:55 pm
    Trim with numeric keypad entry…
    This no longer works with the fn + j. I just switched from FCP7, and typing in a value to nudge a clip is a shortcut I use constantly.
    The apple keyboard doesn’t have a number pad. Any other solution?
    December 16, 2014 at 9:29 pm
    Yeah, Apple seems to have finally killed the built in numpad on their laptops.
    However, a USB numpad can but had for less then $10, so that’s probably the easiest solution.
  • Ryan Aqu
    December 17, 2014 at 4:46 pm
    I found this program that actually brings back the functionality. It works GREAT! It’s kinda odd to get used to though. I liked just being able to (Shift + then type the number in FCP7)
    Now I have to (fn + / then type number)
    https://pqrs.org/osx/karabiner/index.html.en
