Activity Forums Adobe After Effects Can you render the front camera view?
  • Can you render the front camera view?
    Posted by Mark Young on April 28, 2008 at 8:26 pm
    I was hoping someone could help me out with the following problem:
    I’m trying to render out the front view camera in After Effects (not the active camera). The reason I’m after the front view is because it acts as a orthographic camera rather than a perspective camera.
    Am I making sense here? It’s kinda hard to explain.
    Bendik Ramm replied 11 years, 5 months ago 7 Members · 10 Replies
  • 10 Replies
  • Mark Young
    April 28, 2008 at 9:34 pm
    Thanks for the reply,
    Unfortunately the effect I’m looking for doesn’t work with a camera (or no camera) in the comp. I want to get a render that has no perspective (as if you were looking at a front elevation on a blueprint).
    Even if I have no camera in the comp the view still shows some perspective.
  • Travis Roop
    April 28, 2008 at 11:36 pm
    I was thinking the same thing, use a Screen Cap program, snapX for mac is what I have, then capture the comp in AE while it plays in the desired camera mode.
    Travis Roop
    Editor
    bitMAX Hollywood
    troop@bitmax.net
  • Alejandro Torres
    April 29, 2008 at 1:20 am
    there’s a great free plugin from obvious FX called copy image.
    https://www.obviousfx.com/products/copyimage/copyimage.php
    Install it and use it (frame by frame) and you can avoid the cropping that the screen grab would force you to.
    Hope it helps!
    Regards
    Alejandro
    http://www.fxtudio.com
  • Mark Young
    April 29, 2008 at 1:38 am
    Thanks for the help guys, man I wish Adobe would just have a render view option like most 3d apps!
  • Darby Edelen
    April 29, 2008 at 3:30 am
    [Mark Young] “Unfortunately the effect I’m looking for doesn’t work with a camera (or no camera) in the comp. I want to get a render that has no perspective (as if you were looking at a front elevation on a blueprint).”
    You can’t render the Front view. You can, however, create a camera with a ridiculously long focal length (zoom) that would almost eliminate perspective. You could link the camera’s Z position to its zoom:
    x = thisComp.width / 2;
    y = thisComp.height / 2;
    z = -cameraOption.zoom;
    [x,y,z]
    Then keep increasing the zoom value until it looks close enough… or AE crashes (;
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Tim West
    April 29, 2009 at 11:12 am
    How about previewing this at the highest res and then saving the preview?
  • Tim West
    April 29, 2009 at 11:20 am
    (just tried this and AFX will not allow you to save the front view preview, needs to be the active camera)
  • John Breslin
    July 27, 2013 at 7:31 pm
    This is a bit late, but you could just save the RAM preview.
  • John Breslin
    July 27, 2013 at 7:41 pm
    Nevermind
  • Bendik Ramm
    March 31, 2015 at 11:38 pm
    Not a perfect solution but an easy workaround: if you move the camera far away and zoom in on your model there will be next to no perspective distortion. It helps to manually enter the values of position and zoom to have an “exact” position (especially when you use simple geometries like cubes etc.).
    Hope that helps.
