Activity › Forums › AJA Video Systems › Can you Recording 20 hours straight with the Ki pro?
  • Can you Recording 20 hours straight with the Ki pro?
    Posted by Jacob Varela on July 29, 2010 at 4:41 pm
    Hi guys,
    I had a question, I have 20 hours of footage I need to capture. After doing a couple of tests and poking around came to the conclusion correct me if I’m wrong Final cut has a limitation of up to 4 hours that can be captured straight without stopping.
    I wanted to know if I can use the ki Pro to capture the 20 hrs footage straight? I did the calculations and it would br useibg about 445 GB leaving more then 10% of the drive free.
    Do you know if it is possible or do you have a different alternative?
    Jacob
    Jacob Varela replied 16 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
