Activity Forums Canon Cameras Can you record higher quality slow motion with C300 MKII when paired with Odyssey 7Q+?
  • Can you record higher quality slow motion with C300 MKII when paired with Odyssey 7Q+?
    Posted by Isaac Senechal on February 26, 2019 at 3:49 pm
    The question is really in the title. I can see the higher quality or easier workflow options that the Odyssey 7Q+ allows you to have when used with the Canon C300 MKII, but it doesn’t seem to help with high frame rates. As far as I can tell, the Odyssey can only record Canon RAW up to 30fps.
    Looking online, I saw mention of something called “Half RAW” or half quality RAW. Perhaps that can be used up to 60fps…? If so, how?
    If not, then maybe at least the Odyssey can allow you to bypass the quality loss necessary when shooting either S&F recording 60fps rate or regular 60fps. Internally, the former option can only be done with YCC 4:2:2 10 bit while the latter can be done in this same format or also RGB 4:2:2 10 bit (instead of the better 4:4:4 12 bit possible with 24 and 30fps)
    Does anyone out there have answers to my numerous questions!??
    Isaac Senechal replied 7 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
