Activity › Forums › Storage & Archiving › Can you recommend a raid controller for a simple RAID0 video editing setup?
Posted by David Payne on January 24, 2015 at 9:01 pmhi all i’m a video editor and my motherboard based raid 0 let me down last year so I’ve been running on single drives since then. Now the season has quietened down I’d like to set up a better quality raid and use 2x 1tb HDD’s store video on and 2x 1TB HDD’s to use as a cache drive. IF the hardware based raid controllers (have never used one before) allows, I’ll probably get another 2x 1TB HDD’s to make my video raid drive 2TB in total instead of 1TB.
Can you guys recommend a raid card that is not mega expensive but is reliable and crucially simple for a know nothing to set up!
If it makes any difference the drives I’m using are 1TB WD Caviar Blacks.
David Payne replied 11 years, 7 months ago 4 Members · 20 Replies -
David Roth weiss
January 24, 2015 at 9:35 pmYou’ve not mentioned whether you’re on the Mac or PC platform – not that it matters for the top two Raid controllers, as they are cross platform, but like many questions, the answer is a tad more complex than you seem to think.
David Roth Weiss
Director/Editor/Colorist
David Weiss ProductionsDavid is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
David Payne
January 24, 2015 at 9:36 pmSorry, I don’t really know anything about them. I’m a pc user, Intel i7,windows 7 64bit,32gb ram
David Roth weiss
January 24, 2015 at 10:15 pmI understand…
The two best RAID controllers are Areca and ATTO, but they are a bit pricey, at about $950 to $1100 each. They both come in a variety of flavors, depending upon how many ports you need internally and externally. The Areca 1882 series are a bit easier to deal with typically.
There are less expensive controllers by LSI that aren’t bad, but don’t be tempted by RocketRaid cards, as their support bites.
One more very important fact is, no RAID protection scheme is foolproof, so don’t think that RAID 5 means no backups are necessary. The RAID 0 issue you had should not have been a disaster, as you should have had a backup. So, with that being said, maybe you really need more backup drives, not a RAID controller?
David Roth Weiss
David Payne
January 24, 2015 at 10:19 pmNope it was not a disaster, hence wanting raid0 again. I want it solely for speed. I’m under the impression that 1x drive is slower than 2x identical drives raid0’d together, is that correct?
David Roth weiss
January 24, 2015 at 10:28 pmEvery time you double the number of drives in a RAID array you virtually double the throughput. So yes, two drives striped together as RAID 0 will have twice the thriughput of a single drive. The reason many buy an 8-drive RAID is that it has enough throughout and space for most users for a long, long time, allowing one to grow over time without making a new major purchase for a long time.
David Roth Weiss
David Payne
January 25, 2015 at 8:08 amIf I go for 8 port, do I need to use all 8 or can be I just use 6 for the time being?
Are any of these not awful?
https://www.scan.co.uk/search.aspx?q=%20%20%20%20Lsi%20raid%208%20port
Sonic 67
January 25, 2015 at 11:16 pmYou can use how many you want. RAID options will be different (like RAID5 needs minimum 3 drives, RAID 10 minimum 4…).
However, The more drives you have in RAID 0, the more increase the chances for a disaster. The probability of a failure is multiplying accordingly.
For long-term storage try at least a RAID 5 (for redundancy) – with three drives it will have 2/3 capacity of a single drive, with 4 drives will have 3/4.I am using now a controller that I got from eBay – 3ware AMCC 9650SE-4LPML.
It’s performance during video rendering is above and beyond what my Intel ICH10R could do (with the CPU used at 100% by video software). -
David Payne
January 26, 2015 at 3:23 pmthank you, one recommendation is all i need as I’m really keen to get one asap. Unfortunately I can only find your one for sale in the states so may have to go down that route
Can you confirm that’s correct?
Also excuse the silly question but I don’t see 8 ports on the card.. how do the HDD’s connect or does just one connect to it?
Sonic 67
January 27, 2015 at 11:27 amThe 9650SE-4 is just a 4 port card. The -8i is the 8 port card (couldn’t find in UK ebay.
Example link on US ebay
Another example link. -
David Payne
January 27, 2015 at 11:30 amwould you mind taking a look on here and telling me if any stand out as doable?
https://www.scan.co.uk/shop/computer-hardware/all/hdd-controllers/all
