Activity › Forums › Apple Final Cut Pro Legacy › Can you recommend a high quality Quicktime to AVI converter?
  • Can you recommend a high quality Quicktime to AVI converter?
    Posted by Ron Moody on January 24, 2007 at 12:41 am
    Needs to be capable of converting half hour quicktime files (approx 6 gig) NTSC D1 720×480 to avi.
    Thank you
    Ron from Maui
    Ron Moody replied 19 years, 8 months ago 4 Members · 5 Replies
  • Jerry Hofmann
    January 24, 2007 at 12:45 am
    FCP can do this directly… file/export/using qt conversion…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Shane Ross
    January 24, 2007 at 12:47 am
    Or Compressor, so that it can happen in the background.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Ron Moody
    January 24, 2007 at 2:55 am
    Per Apple’s tech notes, Quicktime is limited to one gig. I’ve actually gotten a little over two gig before the avi becomes unusable, but there is a limit to avi’s you can output from FCP. The limit I’ve discovered is around ten minutes or so. I haven’t fine tuned it any closer, execpt that I know 15 minutes doesn’t work.
    ron
  • Neil Ryan
    January 24, 2007 at 4:14 am
    Take a look at ‘MPEG Streamclip.’
    It is available for Mac & PC at:
    https://www.squared5.com/
    and as it’s free, you will be guaranteed to get your money’s worth …
    Neil.
  • Ron Moody
    January 24, 2007 at 5:39 pm
    Thanks, I downloaded it last night. I guess I erased the old files since I can’t find them now. I’ll turn out a new 29:30 quicktime file today and try it out. I was encouraged to see that they state there is no quality loss in converting quicktime to AVI.
    I’ll bet there is a long line of Mac purists that would argue that point. (In case my ‘subtle’ jab isn’t clear, I’ll bet there is a long line of Mac purists that would argue that the avi format can’t hold a candle to quicktime.) I have no desire to argue that point, especially since I think it’s very likely true.
    Thanks again,
    ron
