Activity Forums Compression Techniques Can you read timecode into a log file?
  • Can you read timecode into a log file?
    Posted by Angelo Lorenzo on July 19, 2012 at 1:24 am
    Since FFMPEG and FFMBC can’t copy a data stream from a Quicktime file (where timecode is stored), I have to resort to setting the timecode using the -timecode command in some instances.
    Is there any way to read the filename and timecode into a log file that I can then use to power a python script or batch file for when I actually convert the MOV file?
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Mark Burton replied 11 years, 6 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    July 19, 2012 at 2:06 am
    Nevermind, seems like the 2> command will do just fine.
    Angelo Lorenzo
  • Mark Burton
    March 5, 2015 at 9:23 pm
    Could you elaborate on what you ended up doing? I’m looking for a way to read the input files timecode and make the starting timecode value available to the drawtext filter so I can burn it into the picture. Currently I’m having to set the timecode manually for each input file. Thanks.
