Activity › Forums › Apple Final Cut Pro Legacy › Can you pan audio tracks on t/l before adding content?
Posted by Steve Dann on September 25, 2010 at 2:08 pmThat’s it really, I kow how to pan individual clips or whole tracks and how to select stereo and mono for the t/l but is there a way to set pan on tracks before you start dropping clips in.
Ideally I’d like tr 1 left tr 2 &3 centre.Nick Meyers replied 16 years ago 4 Members · 3 Replies -
Jerry Hofmann
September 25, 2010 at 3:26 pmNo way to do this to a track before you’ve added the clips I’m afraid.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
John Fishback
September 25, 2010 at 4:49 pmYou can speed-up the process by setting the pan of your first clip, copy it (Cmd-C), select the following clips, and then Paste Attributes (Opt-V) select Audio > Pan.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Nick Meyers
September 27, 2010 at 12:03 pmyou cant assign any value or effect to individual tracks,
BUT
you can assign a specific OUTPUT to an individual track.
so if you have an i/o card with lots of audio outs you can set your timeline up so that specific tracks send to specific outputs.you do all this in the sequence settings > audio outputs panel.
if your audio card is feeding a mixer you are all set.
QuickTime Movie exports from this timeline will have separate mono audio tracks for each separate output.nick
