Activity › Forums › Adobe Premiere Pro › Can you open a CS3 project in CS2
Posted by Dorian Richmond on February 5, 2008 at 9:57 pmIn PPRO CS3, is there any way to save a version of a project that would still open and be editable in CS2?
Jon Barrie replied 18 years, 7 months ago 3 Members · 2 Replies -
Baz Leffler
February 5, 2008 at 11:17 pmYes it sometimes can be done but try opening a NEW PPro 2 project and import the CS3 project into it as that bypasses any differences that may exist between the 2 versions.
If that causes problems then open the CS3 project and copy the whole contents of the timeline into the clipboard and then open CS2 and paste into it’s timeline. Of course you have to have both programs on the same computer to do the later.Baz
What would I do without the ‘UNDO’ button!!!!
Jon Barrie
February 6, 2008 at 11:55 pmYou could try using the AAF export (It will be a simple cut of it) or EDL export (might not keep effects – will need to work with one video track and relink the footage) and import either of them into CS2.
– Jon 🙂How many editors does it take to change a light bulb?
