Activity Forums VEGAS Pro Can you move tracks without dragging with the mouse?
  • Can you move tracks without dragging with the mouse?
    Posted by Morgan Lewis on November 13, 2012 at 2:40 am
    My friend and I do some recordings that need to be synced up perfectly with the video we record, as both contain game audio and would sound weird if not synced up.
    I do this by zooming out and then slowly dragging one of the audio files while playing a small piece looped. But although this works I can’t help feeling there could be a more precise way.
    I can already use the arrow keys to move a frame forward or back at a time, is there a way I can move a track down or up the timeline a frame at a time?
    Morgan Lewis replied 13 years, 10 months ago 3 Members · 5 Replies
  • Graham Bernard
    November 13, 2012 at 4:28 am
    Uncheck Quantise to Frames. This’ll allow you to move the Events at an inter-frame level.
    Grazie
    Cameras: Canon XF300 and two elderly XM2s
  • Morgan Lewis
    November 13, 2012 at 6:27 am
    I’m not entirely sure where that option is, I’m using Sony Vegas Pro 10 if that helps.
  • Graham Bernard
    November 13, 2012 at 7:21 am
    [Morgan Lewis] “I’m not entirely sure where that option is, I’m using Sony Vegas Pro 10 if that helps.”
    Sure:
    Options >> Quantize To Frames – OFF
    PLUS
    Options >> Enable Snapping – OFF
    This will allow you to override both the SNAP of single frame adjustment and the ability to slip Audio.
    NB: Remember to turn back on!
    Grazie
  • Matt Crowley
    November 13, 2012 at 8:21 pm
    Check out the “keyboard shortcuts” list in the Vegas help.
    Select the event you want to nudge along the timeline, start your loop playing if you need, and tap num-pad 1 and 3 to nudge the event left/right by one frame at a time.
    If you’re on a laptop with no separate number pad, check if the keyboard has a numpad overlay using a FN key or similar. For example, my Dell laptop uses FN + 7/8/9/U/I/O/J/K/L/M as the number pad.
  • Morgan Lewis
    November 15, 2012 at 5:16 am
    Wow I’m observant, hah, was looking for it in Tools and not Options, thanks. 🙂
    And Matt, you are a god, that is going to save me so much hassle, I just synced my latest project so much easier now I have precise controls, thank you. ^^
