Activity › Forums › Adobe After Effects › can you move mask shapes together?
Posted by Joshua Rule on October 25, 2005 at 10:30 pmI have a mask with several keyframes on the shape I want to move all my keyframed shapes a few pixels up. Is there a way that I can do every one at one time or do i have to do each keyframe individually.
JoshMilesl2@mac.com replied 20 years, 11 months ago 4 Members · 5 Replies -
Mike Clasby
October 26, 2005 at 12:39 amTry this:
Get to the frame where the keyframe is. With the Selection Toll (V) double click on any of the verticies (like nodes) of the mask. You get a little Tansform box around the Mask like in Photoshop, you can rotate, skew, lengthen-shorten. You can also move it up with the arrow key. I don’t know if they only move it one pixel at a time, but it’s not much.
Joshua Rule
October 26, 2005 at 3:45 pmthat is not what I meant. I have like 50 shape keyframes on my time line. I want to move each one of those keyframes 5 pixels up. I want to move each keyframe 5 picels up all at once rather than having to go on each keyframe and hit 5 pixels up. You can do this with thingslike position on layers but for some reason ti doesn’t work with masks.
Steve Roberts
October 26, 2005 at 4:04 pmHmm … wouldn’t moving the layer’s position up 5 pixels do the same thing as moving all masks up 5 pixels?
If you just wanted to move the masks (not the layer), maybe you could move the layer up, then use the pan behind tool to move it back down? Or precompose?
Steve
Milesl2@mac.com
October 26, 2005 at 6:18 pmThis might be a bit more complex than needed, but you could place your current mask on a black or white solid and use this as a track matte for the footage the mask is on now (feathering and expansion will still work as needed). If you need to shift five pixels up, just simply move the layer with the mask on it up and it won’t move the footage as Steve’s suggestion would.
Milesl2@mac.com
October 26, 2005 at 6:26 pmJust wanted to fill in some of the details I left out. The black solid would likely need to be pre composed in a comp with the background color (or a layer placed below) set as white to give you a proper matte layer. Hope that helps.
ML
