Activity Forums Apple Final Cut Pro Legacy Can you mix ProRes flavors in the same project?
  • Can you mix ProRes flavors in the same project?
    Posted by Kim Fox on June 1, 2011 at 8:02 pm
    Hi all,
    Project was shot in ProRes4444.
    Most of the footage was transcoded to ProRes 422(LT) for offlining.
    A few clips will not transcode.
    However, the “trouble” clips will import into and play in a separate project I created in FCP.
    Is is possible to just use the 4444 clips in the project with the 422 clips, just for the offline?
    Thanks so much!
    Kim
    Rafael Amador replied 15 years, 3 months ago 2 Members · 1 Reply
