Activity › Forums › Adobe After Effects › Can you mask an effect?
  • Can you mask an effect?
    Posted by Erin Anderson on December 20, 2011 at 3:05 am
    What I want to do is have it snowing in a snow globe. So I thought I’d make a circle and try to have the snow effect in there. But when I apply the effect to a circle, the entire screen snows and not in the circle. I don’t know if I can mask an effect in a circle. Is this possilbe? If so, how do you do this?
    Thank you!
    Kevin Camp replied 14 years, 9 months ago 3 Members · 2 Replies
  • Angie Taylor
    December 20, 2011 at 9:06 am
    Hi there,
    There are a couple of methods for masking effects. The first is to apply the effect to an adjustment layer and mask the adjustment layer. however I don’t think that’s what you need here.
    To use a Mask to contain particles is usually done within the effect itself and how you do it depends on which particle system you’re using. In Particle Playground you can use the Wall settings to use a mask to contain the particles. In Particular you can’t really use a mask in the same way but you can use a layer with an alpha channel to control the particles and create a Wall for them to bounce off in Bounce mode. Alternatively, in Air mode you can set up a spherical field to control the particles.
    Let me know what software you’re using and I’ll try to give you more detailed instructions.
    Hope this helps.
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Kevin Camp
    December 20, 2011 at 3:28 pm
    rob mize has a tutorial here that i think uses all standard ae effects (no 3rd party effects) to make a snow globe:
    https://library.creativecow.net/articles/mize_rob/Snow-Globe/video-tutorial
    the main snow portion uses cc particle world and cc sphere, but he also builds out reflections and a base
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
