Activity Forums Adobe After Effects Can you make objects bounce off other objects in AE?
  • Can you make objects bounce off other objects in AE?
    Posted by Scott Green on April 18, 2012 at 10:46 am
    I was watching this video:
    https://www.youtube.com/watch?v=gkQoCCsu_fA
    And wondered if it had been made in After Effects or some other type of fancy software. The shapes are really basic but I like the way that objects such as the ball bounce off other objects really realistically like they have the perfect amount of gravity and bounce (or a more technical term!) to them.
    Do you think it’s possible to create this type of effect in AE? Maybe using a plugin in of some sort?
    I really do love good design – https://www.splurj.com
    Thomas Hannen replied 14 years, 5 months ago 3 Members · 3 Replies
  • John Cuevas
    April 18, 2012 at 10:52 am
    Check out Newton, the physics engine for AE at Motionboutique
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Scott Green
    April 19, 2012 at 9:34 am
    That’s amazing, I never knew about this plugin, it’s time to dig into my piggy bank I think! Thanks John.
  • Thomas Hannen
    April 23, 2012 at 10:02 am
    You can also bounce particles off from up to 2 surfaces using Trapcode Particular. Mentioning this in case you already have it. Newton sounds like a better choice in this instance, but I haven’t used it. I believe there are also some very complicated ways to do this using the built in particle plugins, but involves lots messing around with displacement layers shaded to bounce from (see some of the Foam tutorials).
