Activity › Forums › Adobe Premiere Pro › Can you make low res proxies for just the clips in a sequence?
  • Can you make low res proxies for just the clips in a sequence?
    Posted by Conrad Turner on July 8, 2014 at 1:47 am
    Apologies if this has been asked before… I couldn’t find anything though when I searched.
    Is there an easy way to make low resolution proxies for just the clips that appear in a sequence, not the entire project? Ideally looking for a solution that doesn’t involve one clip at a time 🙂
    Alex Udell replied 12 years, 2 months ago 2 Members · 1 Reply
  • Alex Udell
    July 11, 2014 at 12:46 am
    This is not very easy…..(because there is no decompose option in PPro)
    You could:
    select all and copy all clips from your sequence…
    jump to AE and make a comp that is the same resolution as your sequence.
    paste all your clips into the AE COMP…
    then use this AE script from video co-pilot(install this in AE first): https://www.videocopilot.net/tutorials/trim_compose_script/
    to precomp all you clips in the AE comp….
    (this will allow you to precomp and trim them with optional handles)…
    then in your AE Project panel you should be able to select all your precomps and send to batch in Adobe Media Encoder to create your low res proxies…(note that I’d open AME 1st and set your destination preference and you select your encoding preset…so that it will get applied to all the incoming comps.)
    that will allow you to make a low res set of media….but doesn’t do any linking to your sequence in Ppro or anything….
    does that help?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
