Activity Forums Apple Final Cut Pro Legacy Can you link 4 channel audio?
  • Can you link 4 channel audio?
    Posted by Christie Allanson on July 18, 2016 at 8:51 pm
    Using FCP 7, I’ve got footage here with 4 channels of audio (though sound only visible in waveforms on first two channels). I was wondering if you can link them and make them act like a stereo pair, like you can with two channels?
    For example, I’m using the pen tool a lot, and at the moment I have to draw on each channel separately which is pretty time consuming. Is there a way I can draw on one and it copies on the others, like with a stereo pair?
    Thankyou!
    Christie Allanson replied 10 years, 2 months ago 3 Members · 3 Replies
  • Shane Ross
    July 18, 2016 at 10:01 pm
    Highlight them and press CMD-L.
    Shane
    Little Frog Post
  • Nick Meyers
    July 19, 2016 at 7:54 am
    Yes, and no.
    yes you can links the 4 tracks, as Shane says, (and indeed you SHOULD have them linked)
    but no, they won’t behave the way you want them to, like a Stereo clip.
    your rubber-banding of the audio level is on a single track only.
    often this is good, as the separate tracks often have quite different audio.
    but when you quickly want al tracks to follow that same volume graphing, its a pain.
    what i do after key-faring the first track, is to select the clip (all tracks)
    Copy (Command C)
    then Paste Attributes (Option Command V)
    you get a warning “can only copy from the first track” (or something like that), but that’s OK.
    select Levels in the Paste Attributes window, hit OK, and you’re done.
    still a bit of a drag….
    obviously if it’s to ease something in or out, just add an audio transition.
    cheers,
    nick
  • Christie Allanson
    July 20, 2016 at 6:29 pm
    Oh yes, I should’ve been more clear. They are indeed linked, I just wanted them to behave like a pair.
    Paste attributes is much faster than drawing 4 times – brilliant, thank you.
