Activity › Forums › Adobe After Effects › Can you keyframe Wiggle?
Posted by David Del on July 4, 2008 at 9:10 pmI want to keyframe a wiggle expression – wiggle (5, 20), but I am not sure how to do it. When I change the wiggle value, it stays changed. Is there a way of going from wiggle (0,0) to wiggle (5,20)?
thanks
David Del replied 18 years, 2 months ago 4 Members · 5 Replies -
Sam Young
July 4, 2008 at 10:41 pmthe key is to use an Expression Control effect to keyframe your wiggle values.
Aharon Rabinowitz
July 4, 2008 at 11:59 pmclick on my head up at the top – it will take you to some tutorials. Find the ones called Expression Controls Pt1 – 3. Pt. 3 explains exactly how to do this.
Aharon Rabinowitz
Email: arabinowitz (AT) yahoo (DOT) com
All Bets Are Off Productions, Inc.
Creative Cow After Effect Podcast
Internet Killed the Video Star: A Guide to Creating Video for the Web -
David Del
July 6, 2008 at 7:58 pmFirst off, thanks for that. It really helped –
Now the secondary issue : when I use Wiggle, my text will often flash off/on. I am not sure why it does this. When I get rid of the wiggle expression, the text stays solid. When I add a wiggle expression, it sometimes disappears. Any ideas what is going on here?
Mike Clasby
July 7, 2008 at 6:22 amI assume your wiggling the position, no? How big is the wiggle? Is it wiggling off the screen momentarily?
David Del
July 7, 2008 at 4:38 pmNo it was very small (10,2). I am going to try something else, maybe keyframe it by hand.
