Activity Forums Maxon Cinema 4D Can you keyframe the polygon selection tag visibility?
  • Can you keyframe the polygon selection tag visibility?
    Posted by Scyld on April 4, 2014 at 4:16 pm
    hi
    i have a simple polygon shape (see attached C4d file 7323_polygonreveal.c4d.zip), and i’d like to reveal different panels of it, bit by bit. is there a way to animate the selection tags’ visibility? so i can toggle between 100% visibility and 0%?
    sounds simple but i’m struggling to figure out how this would work… or is there an easier way to do this?
    any advice would be very gratefully received. thank you.
    Scyld replied 12 years, 5 months ago 2 Members · 6 Replies
  • Brian Jones
    April 4, 2014 at 4:58 pm
    you can add an alpha material and keyframe between it and the colored materials in the Material slot of the texture tags
  • Scyld
    April 4, 2014 at 5:08 pm
    many thanks for the quick response! i’m not sure how i would go about that… could you expand on it or show me an example?
  • Brian Jones
    April 4, 2014 at 5:43 pm
  • Scyld
    April 4, 2014 at 6:10 pm
    genius! love it. perfect solution. thank you very much!
    one question: how come the texture doesn’t generate in betweens? its either on or off. if i wanted to fade them on, would that be possible?
  • Brian Jones
    April 4, 2014 at 6:39 pm
    you said toggle so that’s what I was thinking, it is possible, if the materials all have the same channels enabled it does fade between the materials between keyframes
    7325_polygonreveal.c4d.zip
    you have to render to see it though
  • Scyld
    April 4, 2014 at 6:52 pm
    yes i was looking for a simple on/off state, but this is great to know for future work.
    thank you very much for your expertise!
