Activity Forums Apple Final Cut Pro Legacy Can you keep key frame info when pasting Filters?
  • Can you keep key frame info when pasting Filters?
    Posted by Rsk3527 on August 29, 2006 at 9:27 pm
    Is it possible to preserve key frame information when copying and pasting filters from clip to clip. I am doing a show where I need to constantly repeat an effect I create by key framing a filter. When I paste the filter it does not keep the keyframe information, the filter stays static. This is causing quite a bit of frustration. Any help would greatly be appreciated.
    -Rich
    Martin Baker replied 20 years ago 4 Members · 3 Replies
  • Ben Holmes
    August 29, 2006 at 9:50 pm
    Copy (apple+c) the clip with the filters and keyframes you want. Then right-click or control click on the clip you want the filters applied to, and select paste attributes from the pop-up.
    In the paste attributes menu tick ‘filters’ and note the option to ‘scale attributes over clip length/time” (or something similar – don’t have FCP in front of me) – this tells FCP whether or not to spread the keyframes you set on the first clip over the duration of the new clip (so, for example, a move happens over the total length of the clip, regardless of the clip length) or whether it just applies them over the same timeframe, working from frame one of the clip.
    Hope that’s clear. Paste attributes is remarkably useful – even allowing you to apply these filters etc. to EVERY clip you highlight in the timeline. This means your job will require a single click!
    Have fun.
    Ben
    Editec Broadcast Editing Ltd
    EVS & FCP specialists for live OB operations.
    “The Supercar Run” now available for international distribution from http://www.electricsky.com
    See you at IBC – we’re there with our FCP/replay truck…
  • Winston A. cely
    August 29, 2006 at 9:55 pm
    Paste Attributes, is one of my all time favorite tools in FCP. Hands down.
    “If God could do the tricks we can do, He’d be a happy Man.” – Peter O’Toole – “The Stuntman”
    Machine Model: Power Mac G5
    CPU Type: PowerPC G5 (3.0)
    Number Of CPUs: 2
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 512 KB
    Memory: 4.5 GB
    Final Cut Studio (Not Universal, yet)
  • Martin Baker
    August 31, 2006 at 7:32 pm
    Unfortunately Paste Attributes is just like copy/pasting filters in the Filters tab and won’t place the keyframes in the right position. I don’t know whether this is by design or a bug.
    What will work however is simply dragging the animated filter from the Filters tab to the clip(s) on the timeline. The keyframes get correctly repositioned relative to the new destination clip.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! BigTIme – resizable timecode display for FCP
