Activity › Forums › Adobe After Effects › Can you have more panels of the same type open simultaneously?
  • Can you have more panels of the same type open simultaneously?
    Posted by Alexander Pedersen on November 25, 2016 at 3:20 pm
    Hi gurus!
    I know you can have multiple viewers but can you do the same thing for other panels?
    In this specific instance I have a control layer with Slider Controls on which I use to control whether effects are on or off on a lot of other layers. Instead of constantly double clicking this control layer I would like to keep it open at all times in a separate window. I would like to have two instances of the Effect Controls panel in which I would “Lock” (with the Lock symbol as with Viewers) the one and have the other one unlocked. Is this possible? I have a feeling it’s not. I could see this usable with other types of panels as well but it seems the viewer is the only one possible. Please prove me wrong!
    Regards
    Alexander
    Alexander Pedersen replied 9 years, 10 months ago 2 Members · 3 Replies
  • Alexander Pedersen
    November 30, 2016 at 5:50 pm
    Bump!
    Messing around in After Effects and Premiere Pro
    Specs for whenever I forget to include it in my oh so many forum questions:
    Windows 7 Ultimate 64-bit
    CPU: Intel i7-4770K @ 3,5GHz
    RAM: 16 GB G.Skill 2133MHz
    GPU: GeForce GTX 760
    Motherboard: ASUS Z87-Pro
    Seagate 1 TB
  • Walter Soyka
    November 30, 2016 at 5:57 pm
    [Alexander Pedersen] “I would like to have two instances of the Effect Controls panel in which I would “Lock” (with the Lock symbol as with Viewers) the one and have the other one unlocked. Is this possible?”
    Click on the name of the layer in the title bar of the effects control panel (right next to the words “Effect Controls”), then select “New Effects Control Viewer.” You can create as many ECPs as you like and lock them to specific layers.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
    December 1, 2016 at 11:26 am
    [Walter Soyka] “Click on the name of the layer in the title bar of the effects control panel (right next to the words “Effect Controls”), then select “New Effects Control Viewer.” You can create as many ECPs as you like and lock them to specific layers.”
    YES!! Exactly what I was looking for. Pretty well hidden, Adobe! Thank you, Walter!!
