Activity › Forums › Adobe Premiere Pro › can you have a keyboard shortcut to make an audio keyframe?
Posted by Allen Bartnick on September 24, 2005 at 12:17 amI can’t find a way to create a keyboard shortcut to add an audio keyframe in the timeline. Is their an easy way to ride the audio levels?
Thanks in advance,
Allen
Steven L. gotz replied 21 years ago 4 Members · 4 Replies -
Mike Velte
September 24, 2005 at 11:46 amThe Audio Mixer can add volume keyframes as you “ride” the track slieder in any mode but “read”, but beware…the keyframes are “track” not “clip” keyframes and dont move when you move a clip.
Paolo
September 24, 2005 at 12:47 pmSo, if i insert for example 5 seconds of black in insert mode at beginning of the timeline in all the tracks, then i must adjust again the keyframe on all the audio tracks???
Steven L. gotz
September 24, 2005 at 10:13 pmYes. The audio mixer works on tracks, not on clips. You move the clip and the keyframes do not move.
Get used to using nested sequences. That way, the entire sequence looks like a single clip. So adjust your audio on one sequence, then use it in another.
Steven
Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
