Activity › Forums › Panasonic Cameras › Can you go HVX200 straight to Hard Drive?
  • Jason Bean
    July 30, 2008 at 4:23 pm
    Nate,
    Thanks for the tip. Setting te TC at free run helped capture longer clips, but I am not getting HD even when I set the capture settings to 1080 HD in FCP. Does the camera need to be in a certain mode or is there another setting in FCP that I am missing? It still comes out 4:3 and in SD.
    Jason
  • Nate Stephens
    July 30, 2008 at 7:06 pm
    The HVX200 shoots in DV, DVpro, 720, and 1080…. It is not just one of them so yes might be your answer… I do not have the camera in front of me…. Dig thru the menu… It will work..
    FCP, Mac Pro, Mac Book Pro, HPX500, HVX200, Betacam, Dvcam
    Write for the Edit, Shoot for the Edit, Edit…..KISS Principle
  • Jason Bean
    July 30, 2008 at 7:59 pm
    Duh…Switch it to P2 to open up the HD camera settings. So Simple it ran right by me. Thanks for the push off the lazy ledge into HD freefall.
    Jason
  • Paula Alves
    October 14, 2008 at 8:59 pm
    Hello Nate,
    I did everything you said, so I could capture the video… The only problem is that I couldn´t capture it in 24p…
    Do you have any idea of what might have happened?
    Thank you in advance,
    Paula
  • Nate Stephens
    October 15, 2008 at 2:00 am
    Paula,
    I do not have the camera set up. And I am sure I was testing with 1080i/30 or 29.97 frames…
    I do not know if their is a 24p limitation on it or not..
    Make sure your camera is on free run for the computer must see running time code. Make sure the FCP project is set for 24p and the “capture now” window has uncontrollable device selected..
    Let me know if you get it to work…. What are you recording too /How..
Page 2 of 2
