Activity Forums Adobe After Effects Can you explain this loss os quality?
  • Can you explain this loss os quality?
    Posted by Ns-5 Sonny on November 5, 2007 at 12:13 pm
    Hi guys, I hope somebody can help me to solve this problem.
    I’ve edited in Premiere Pro 2.0 my sequence, then I open my After Effects 7.0 and import the .avi sequence.
    When I add it to the comp, the imagem becomes terrible, there’s a unexplainable loss of quality…
    What am I doing wrong?
    If I double click my .avi file and play it even inside After Effects, its quality is ok… Take a look at the printscreen I’ve made, and if you can, please help me… https://img249.imageshack.us/img249/3607/lossofqualityqv6.jpg
    Darby Edelen replied 18 years, 10 months ago 3 Members · 2 Replies
  • Richard Harrington
    November 5, 2007 at 1:59 pm
    Check the quality setting of your AE comp window
  • Darby Edelen
    November 5, 2007 at 3:21 pm
    Your footage is currently set to “Separating (Lower Field)”
    Is this correct? If your footage is progressive then it should not have field separation on, if it was recorded with a pulldown then that should be removed.
    If your footage is, in fact, interlaced lower field first, then you should go into Interpret Footage (cmd+f on Mac, ctrl+f on PC with the footage item selected) and try the “Preserve Edges” checkbox.
    If you remove fields from a progressive source you end up with a loss in lines of resolution.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
