Activity Forums Apple Final Cut Pro Legacy can you email a bin?
  • can you email a bin?
    Posted by Paul01 on May 2, 2005 at 9:20 pm
    can i email a bin to somebody?
    i am helping out an editor and we are each working from our homes. instead driving back and forth can’t we just email a bin? and if i have fcp xpress will she be able open the bin in fcp 4.5? i used to do that with avid all the time.
    hope somebody can show it to me. i am in the middle of my first fcp gig – i thought the transition from avid would be easier…
    thanks in advance for your help!
    Bret Williams replied 21 years, 4 months ago 5 Members · 8 Replies
  • 8 Replies
  • Digihead
    May 2, 2005 at 9:46 pm
    You can email the whole Final Cut Project file, or if you like create a new Project file and drag the bin you want to send into it. Save it and then email it. It’s as easy as that.
  • Bret Williams
    May 2, 2005 at 11:32 pm
    I was under the impression that FCP doesn’t do timecode. So how does this help?
  • Bret Williams
    May 2, 2005 at 11:33 pm
    I was under the impression that FCP xpress doesn’t do timecode. So how does this help?
  • Bret Williams
    I meant fcp xpress. Doh!
  • Paul01
    May 3, 2005 at 4:36 am
    tried to email project, the reciever couldn’t open it, it said wrong type file…
    so annoying…
    it is about 240 mb, i don’t know.
  • Mark Raudonis
    May 3, 2005 at 6:49 am
    Try compressing the file using stuffit. For some reason this process “protects” the file in transit and proves to be more reliable.
    Mark
  • Martti Ekstrand
    May 3, 2005 at 1:29 pm
    You don’t have to use StuffIt – just ctrl-click (or right-click) the file in Finder and choose ‘Create Archive of …’ and a .zip file is made. StuffIt is not working that well in OSX and StuffItExpander isn’t even included with Tiger.
    cheers
  • Bret Williams
    May 3, 2005 at 4:29 pm
    Another option. Maybe too simple. Export the bin as a batch list. Then email that. Then on the other end, create a new bin and import the batch list.
    However, still begs the question – does FCP Express support timecode? If it doesn’t then it obviously wouldn’t support batch lists either.
    But this method works great for FCP Pro to FCP Pro.
