Activity › Forums › Adobe After Effects › Can you effectively make a Flash website with Encore CS3 and AE CS3?
  • Can you effectively make a Flash website with Encore CS3 and AE CS3?
    Posted by Daniel Haskett on May 30, 2007 at 10:42 am
    Hi there
    Basically ive just been listening to the podcasts about CS3 and the new feature in encore of being to save out as a flash file sounds amazing! From what I can tell you could actually make a website in encore,as you are able to export a fully interactive flash file? Would it then be easy to put this online as a full website do you think? I mean would the file size and stuff still be good?
    The main reason i ask is cause i really wanna do flash websites, but i use after effects and just cant get my head around flash. if itd be possible to use encore and AE together to basically create a website thatd be awesome! i imagine obviously there will be certain things you cant do….but i mean….am i right so far?
    Cheers!
    This is quite exciting….
    Dan
    Frank Hardie replied 19 years, 4 months ago 5 Members · 9 Replies
  • 9 Replies
  • Steve Roberts
    May 30, 2007 at 11:11 am
    Not to be the naysayer, but I think that Encore can’t provide as much interactivity as Flash, and you’ll run up against its limitations more often than you think. Oftentimes, even a simple rollover interaction beyond a DVD’s capabilities requires complicated Javascript in Flash. You’ll have to know the app extremely well to know what it can do, and you’ll end up saying “sorry, I can’t do that” more often than you like. And if you have to say that to a revision request in the middle of a project, the client might not like it. 🙂
    In my opinion, if you want to do Flash websites, you should learn Flash.
    Just my opinion. 🙂
  • Daniel Haskett
    May 30, 2007 at 11:37 am
    and is that even with CS3? cause from what they were saying, you can save out a whole menu you as an interactive flash file….do you still need to know code to do that?
  • Steve Roberts
    May 30, 2007 at 12:11 pm
    I’m going out on a limb to say that I don’t expect Encore to offer any more interactivity beyond the DVD spec, which is limited for the sake of compatibility. I just don’t expect it to offer what Flash can.
    And my point is: even a simple change to the way something rolls over might require Javascript programming beyond the DVD spec, and thus beyond what I expect Encore to be able to do.
    At any rate, you would find more info in the Encore forum, no? 🙂
  • Daniel Haskett
    May 30, 2007 at 12:44 pm
    That is very true 🙂 ive posted on there too, i just know the AE forum always seems to get more replies and there are more people on it, but thanks very much for your help.
    I think once i get CS3 ill have a little play to see how much can be done with it ….but yeah i dont think im gonna learn java anytime soon!
    cheers
    dan
  • Steve Roberts
    May 30, 2007 at 1:26 pm
    Javascript, not java. Big diff. 🙂
  • Adolfo Rozenfeld
    May 30, 2007 at 6:01 pm
    I believe the Flash output feature in Encore is great for repurposing a DVD project to the web. This is no small thing, really.
    I am a bit alergic to the Flash UI and animation model, and would love to have an alternative (like Livemotion wanted to be). However, like Steve said, I don’t think Encore is designed to be flash authoring tool. Of course, the DVD specs are simple but wonderful things can still be created within those boundaries. But I am not sure it will give you enough options in terms of how things are load and/or replaced as you navigate the project. We’ll see.
    Once said that, now that the former Marcomedia technologies are in the same house, I think it’s safe to assume that AE > Flash integration to get better and better with time. I would love to take shape layer or text animation from AE and wire the interactivity in Flash, for example, if it was reasonably easy to do.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    ar(AT)adolforozenfeld.com
  • Wvladik
    May 30, 2007 at 10:42 pm
    i’m glad it’s not just me hating Flash UI. I simply can not stand it.
  • Adolfo Rozenfeld
    May 31, 2007 at 1:35 am
    Well, I wouldn’t say I hate it. I just don’t feel at home with it and prefer the AE animation model (or almost any other animation model I know, for that matter!).
    Adolfo Rozenfeld
  • Frank Hardie
    May 31, 2007 at 6:45 am
    I used to get a little lost in Flash, but the I saw the CartoonSmart tutorials website. This guy is a Flash genius, and his tutorials cover almost everything Flash can possibly be expected 9and not expected) to do.
    Worth checking out if you want to learn Flash.
