Activity Forums Adobe Premiere Pro Can you do Keyframe Time re-mapping in premiere pro?
  • Can you do Keyframe Time re-mapping in premiere pro?
    Posted by 409industries on July 21, 2005 at 4:48 pm
    Hi.
    I have been trying to achieve what i feel is a VERY simple effect, but with no avail. All i want to do is be able to slow a clip down from 100% speed to 50% gradually… so that its not an abrupt slowdown when viewing the clip.
    Is there a way (in premiere pro) that i can accomplish this without an expensive plugin like twixtor? I dont want to it the cheap way either where you cut the clip into 4 pieces and change the speeds from 100% to 75% to etc etc etc.
    I really hope there is a way to use keyframes to control the amount of slowdown between 100% speed and 50%, i really dont care if i can only do a linear slowdown.
    If someone could help me solve how to do this, i would be so happy! thanks!!!
    -Aaron
    Robert Smith replied 13 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Andre Gagnon
    July 21, 2005 at 7:41 pm
    Time re-mapping is not possible within PPro. It is available in After Effects.
    Furthermore, the Speed/Duration setting in Premiere is not keyframable.
  • Nate
    July 22, 2005 at 1:26 am
    Andre,
    [Andre Gagnon] “Furthermore, the Speed/Duration setting in Premiere is not keyframable.”
    Well, obviously, or you’d be able to do exactly what Aaron is looking to achieve: Setting a keyframe at the beginning of the clip for 100% speed and a keyframe at the end of the clip for 50% speed would result in a gradual slowing down from full to half speed.
    Nate
  • Andre Gagnon
    July 22, 2005 at 2:21 am
    [Nate] “Well, obviously, or you’d be able to do exactly what Aaron is looking to achieve: “
    It is not as obvious as you think.
    Time remapping layer process requires more than the ability to set keyframes. It further requires graphs where the Value and Velocity Time Remaps may be adjusted at keyframes.
  • Nate
    July 23, 2005 at 2:37 pm
    Andre,
    [Quote] “Time remapping layer process requires more than the ability to set keyframes. It further requires graphs where the Value and Velocity Time Remaps may be adjusted at keyframes.”
    Regardless of whether or not it requires more than just a simple keyframe or two, if it were keyframeable, you’d be able time-remap a layer, as that’s exactly what keyframes are all about: adjusting from one setting to another over time.
    Nate
  • Robert Smith
    July 16, 2013 at 3:14 pm
    Ive just made the switch from Sony Vegas to Premiere Pro and in Vegas it really is as simple as placing two keyframes in the Velocity envelope. Pretty disappointed if Im honest as I see PPro as the more advanced software
  • Ivan Myles
    July 16, 2013 at 5:07 pm
    [Robert Smith] “Pretty disappointed if Im honest as I see PPro as the more advanced software”
    This thread is eight years old. Use the Rubber Band feature to change speed within a clip. The Adobe Help section Change clip speed and duration with Time Remapping and this tutorial video provide more information. Here are the steps:
  • Robert Smith
    July 16, 2013 at 7:49 pm
    Hah dont know how I didnt spot the fact that this thread was created whilst I was still in secondary school!
    Thanks for your help
