Activity › Forums › DaVinci Resolve › Can you delete optimized media from multiple projects at once in Resolve?
  • Can you delete optimized media from multiple projects at once in Resolve?
    Posted by Duke Sweden on January 18, 2018 at 1:53 pm
    I can’t remember which projects I’ve generated optimized media for. Is there a universal Optimized file and cache deletion function to just wipe out everything? Remember, I’m an amateur, I just play at this, so it doesn’t matter if I delete “necessary” files. I can just regenerate later if I need to. Which I probably won’t.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    DaVinci Resolve 14.2
    Duke Sweden replied 8 years, 8 months ago 2 Members · 4 Replies
  • Tero Ahlfors
    January 18, 2018 at 2:51 pm
    You can delete the whole Resolve cache folder from the OS side. Unless you’ve given it some custom name it should be called CacheClip and it’s under the folder you’ve set as the cache.
  • Duke Sweden
    January 18, 2018 at 3:09 pm
    Thanks Tero. You just cleared 300 gigs from my source drive! What about optimized files? Were those also stored in the CacheClip folder?
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Tero Ahlfors
    January 18, 2018 at 3:29 pm
    That folder has all cached files (smart/user cache, transitions etc.)and all optimized media.
  • Duke Sweden
    January 18, 2018 at 4:00 pm
    Excellent. Thanks again!
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
