Activity › Forums › Apple Final Cut Pro Legacy › Can you cut HDV on external Firewire Drive?
  • Chris Babbitt
    November 7, 2009 at 4:41 pm
    No, in fact you will be better off, if you keep the media on your external drive.
  • Dave Brandt
    November 7, 2009 at 5:12 pm
    Yes you can use an External Drive for HDV. Both USB and Firewire are adequate. It is only when you start using multicam features with 6 or more angles that you will find a bottleneck. For normal editing though it is fine.
    Dave
  • Keith Mcgregor
    November 7, 2009 at 5:19 pm
    Sure can but you’d better off using imac for receptionist
    And get a real machine with an 800 port and always
    Use externals as media drives.
    -K
    Reality? What did you make it?
  • Zane Barker
    November 7, 2009 at 6:09 pm
    [Dave Brandt] “Both USB and Firewire are adequate”
    WRONG, firewire is ok depending of the format of video, but USB is NOT.
    USB works in bursts of data where firewire is a constant stream. Not having a constant stream of data will be vary problematic for video.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Dave Brandt
    November 7, 2009 at 11:11 pm
    It is true that Firewire and USB are using different architecture to control data flow, But as I said, Both are adequate. I have many years of experience using external drives for editing in final cut among others and I can say that USB will do the job just fine. I have edited multicamera shoots in HDV with a portable USB hard drive at 5400rpm. When it comes down to it the data rate of HDV is still only around 3.5MB/s
    To answer the Original Posters Question if external drives are good enough for HDV I would still have to say YES!
    Dave
  • Zane Barker
    November 7, 2009 at 11:58 pm
    [Dave Brandt] “I have edited multicamera shoots in HDV with a portable USB hard drive at 5400rpm”
    Just because you have had fair luck with them does not mean that they are recommended for good video editing performance by any means.
