Activity Forums Adobe Premiere Pro Can you copy captions data from one captions file to another in Premiere?
  • Can you copy captions data from one captions file to another in Premiere?
    Posted by Sara Wasserman on December 13, 2016 at 8:06 pm
    I’ve created a captions file to export to a .srt sidecar file in 1920×1080. The video was shot in 6K so I’m working on another export in that higher resolution. So I have to create 2 separate caption files because of the different sizes. Is there a way to copy/paste the caption data (similar to markers) into the new 6K captions file? Is there a workaround where I can continue with the same 1920×1080 captions file? Thanks ☺
    Sara
    Sara Wasserman replied 9 years, 9 months ago 2 Members · 2 Replies
  • Icaro Lobo
    December 14, 2016 at 1:25 am
    Select your caption file on Project window.
    File > Export > Captions > XML Format
    Reimport the XML into your 6k project.
  • Sara Wasserman
    December 14, 2016 at 3:11 pm
    Thank you! It just worked for me. I’m guessing that the size you select when you create the file doesn’t matter using this method because it looks great in VLC. ????
