Activity Forums Adobe After Effects can you capture video into aftereffects?
  • can you capture video into aftereffects?
    Posted by Geestring on April 12, 2006 at 2:21 am
    I plan on buying a camcorder.. I remember transfering video from a school camcorder to premiere, can you do the same with after effects?
    Tim Kurkoski replied 20 years, 4 months ago 3 Members · 3 Replies
  • John Dickinson
    April 12, 2006 at 3:32 am
    You can’t capture directly into After Effects. You can however capture indirectly via Premiere Pro if you have the latest video production suite.
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Geestring
    April 12, 2006 at 4:36 pm
    why I ask is because I dont want to install premiere as well. You can edit and do everything in Aftereffects…
  • Tim Kurkoski
    April 12, 2006 at 5:23 pm
    Yes, but AE is not necessarily a good program for doing editing in. Just the same way you can do a lot of effects and compositing in Premiere, but AE has better tools for doing those things.
    Each program has their strengths. Unless your editing needs are so very simple that AE really would suffice, use Premiere for what it does best and use AE for what it does best.
