Activity › Forums › Adobe Premiere Pro › Can you avoid duplicate clips with multiple editors using one project?
  • Can you avoid duplicate clips with multiple editors using one project?
    Posted by Jackie Zayble on April 4, 2016 at 3:45 pm
    Hi all,
    I’m converted from FCP7 and am going a bit crazy with media management in Premiere Pro CC 2015.
    We have two editors working on one project — (one makes assemblies while the other fine cuts them). However, we can’t really just import sequences into each other’s project without Premiere duplicating all the media associated with those sequences.
    In FCP7, clips in the browser were just reference — if you deleted them, it wouldn’t affect your sequences. In Premiere, if I import a new sequence, it will import ALL of the associated media of that sequence without the connivence of just deleting it… which is quickly getting out of hand.
    Has anyone figured out a way around this? Can you just redirect the media in the new sequence to the original dailies in your browser? I’ve tried forcing the clips in the sequence offline, but since they’re still associated with the clips in the browser, that’s clearly not the solution.
    Is there any other way around this other than dealing with duplicate files or manually replacing media in each sequence?
    Thanks in advance for any help!
    Hannah Choe replied 9 years, 2 months ago 4 Members · 3 Replies
