Activity › Forums › Adobe After Effects › Can you apply strokes to a non-mask?
  • Can you apply strokes to a non-mask?
    Posted by Hilary Tsai on June 30, 2021 at 11:06 pm
    I have a green screen video and want to add 3D strokes (or just strokes) and have them emanate from my keyed-out subject, kind of like radio waves, which also only works with masks. I want to know if there’s a way to get this effect without generating a mask every few frames of video.
    Thank you!
    Michael Szalapski replied 5 years, 2 months ago 4 Members · 4 Replies
  • Eric Santiago
    June 30, 2021 at 11:35 pm
    You can composite on top of your clip with a mask solid.
  • Hilary Tsai
    July 1, 2021 at 12:42 am
    Yes, but I mean that I want the strokes to move along with the video, not just be a still image outline.
  • Diogo Mendes-pinto
    July 1, 2021 at 8:17 am
    If you use adio Waves you can set “Parameteres are set at” to “Birth” each new wave will take the shape of the current mask shape at that time. If you set it to “Each Frame” the wave shape will change every frame to the shape of the mask shape. So you only have to change the mask shape over time to make the waves change accordingly.
    In your case I think Track Mask is a good option.
  • Michael Szalapski
    July 1, 2021 at 3:53 pm
    AE has a function called Auto Trace that will make the masks for you – you can base it on the alpha simply and then you could use the Radio Waves effect based on the resulting mask.
    Or you could try this sort of technique (adjusting the blur down would make the waves more rigidly follow the shape, but also smaller): https://www.dropbox.com/s/bo3wtv1tkfbvikv/waves%20from%20shape.aep?dl=0
