Activity › Forums › Apple Motion › can you animate a path line
  • can you animate a path line
    Posted by Terry Maloney on August 6, 2016 at 8:11 am
    Hello,
    Can you animate a path line? As the words pass by the line might go lower or slant etc? And then change the slant?
    Thank you,
    Terry
    Simon Ubsdell replied 10 years, 1 month ago 2 Members · 1 Reply
  • Simon Ubsdell
    August 6, 2016 at 9:42 am
    Yes, you can certainly animate a text path, if that’s what you mean. Turn on Record Animation, select the Edit Points tool and keyframe your path – or you can simply rotate it or scale it or whatever you want to do. The text will now follow your animated path. You can also do this with th built-in paths, but you probably want the more flexible option of using Geometry.
    Simon Ubsdell
    tokyo productions
    hawaiki
