Activity Forums Apple Final Cut Pro Legacy Can you add the sequence timecode to a quicktime conversion export?
  • Can you add the sequence timecode to a quicktime conversion export?
    Posted by Michael Buday on March 8, 2006 at 4:47 pm
    Does anyone know if a way in FCP, to export a Quicktime “Conversion” (using the codec of your choice), but have the actual TC of the sequence show up on the QT player counter display instead of the typical start from ZERO?
    It would be nice NOT to have to burn a TC window (though I know it’s easy).
    Thanks.
    Michael Buday
    Nick Meyers replied 20 years, 6 months ago 4 Members · 4 Replies
  • John Pale
    March 8, 2006 at 5:03 pm
    Not with FCP alone. But you can add timecode after export using the free utility Sebsky Tools.
    https://www.dharmafilm.com/sebskytools/
  • Tom Wolsky
    March 8, 2006 at 5:16 pm
    No. Exporting to QuickTime Conversion does not export a TC track. You can however export to QuickTime Movie and make a custom setting for most frame sizes and codecs and that will export a TC track based on the sequence start time.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Tom Wolsky
    All the best,
    Tom
  • Nick Meyers
    March 8, 2006 at 11:07 pm
    tom’s solution is great, and the way to go if you can.
    but if you’ve already exported some files, you can just bring them back into FCP to modify the TC to what you want.
    (open in viewer Modify Menu > Timecode)
    nick
