Activity › Forums › Apple Final Cut Pro Legacy › Can We Run Power Point Presentation File on FCP
Posted by Sulaman Hameed on July 24, 2007 at 2:54 pmHello,
Can We Run Power Point Presentation File on FCP, Can we Import this file or first we make a movie clip.. and also can import Micromedia Flash file on FCP.
I have fcp 5.Sulaman Hameed
Sulaman Hameed replied 19 years, 2 months ago 3 Members · 4 Replies -
Richard Martz
July 24, 2007 at 3:12 pmYes you will have to make a movie since PowerPoint will not run natively within FCP. Same thing for MacroMedia Flash Files. That does not apply to Flash video but I take it you are trying to go the other way.
Richard Martz
MagicMartz MediaFinal Cut Pro HD
Kona LH
After Effects
PhotoShop
Illustrator
Lots of other Fun Stuff! -
Richard Martz
July 24, 2007 at 3:15 pmI might add that there may be a program out there somewhere that might allow Flash files but I’m not aware of it.
Richard Martz
Kona LH
After Effects
PhotoShop
Illustrator
Tom Matthies
July 24, 2007 at 4:39 pmFor the Power Point program, I usually open it in Apple’s Keynote application. Keynote give you the ability to export the show as a Quicktime movie and then bring that into FCP. There are controls for timing the show as well. It usually works well but some playback features depend on the version of Power Point used for the original show.
I’ve done this several times with good results.
Tom
