Activity › Forums › Broadcasting › Can video monitors cause harm?
Posted by John Barnard on July 7, 2005 at 3:01 pmWhen switching on a professional video monitor, is it possible that it emits an electrical charge capable of damaging other computer components?
OS 10.3.9
G5 1.8 single
Huge Mediavault
Atto ul4d2
final cut 4.5
Sony DSR-45Glenn Chan replied 21 years, 2 months ago 3 Members · 4 Replies -
John Barnard
July 7, 2005 at 4:13 pmHappy. I have two CRT computer monitors beside my video monitor. Switching the video monitor on causes a big disturbance in the one immediatly adjacent, but none whatsoever in the further one. I guess I should try to keep everything one monitor length away.
OS 10.3.9
G5 1.8 single
Huge Mediavault
Atto ul4d2
final cut 4.5
Sony DSR-45 -
Charley King
July 7, 2005 at 4:45 pmSounds like shielding problem. Just for grins, put a sheet of foil between the TV monitor and the Computer monitor and see if it makes a difference.
Charlie
John Barnard
July 7, 2005 at 6:44 pmOkay, but I’ll have to be sneaky. My wife is pretty tight with the foil.
OS 10.3.9
G5 1.8 single
Huge Mediavault
Atto ul4d2
final cut 4.5
Sony DSR-45 -
Glenn Chan
July 26, 2005 at 5:55 amThat effect comes from magnetic interference between the monitors.
When a monitor powers on, a lot of them will degauss themselves. Degaussing involves a strong magnetic field that reverses itself often… this will get rid of any magnetic “residue” (non-technical term) in the monitor. Anyways, that’s why you get a big disturbance when the monitor first turns on. Degaussing won’t hurt your monitor, and will sometimes fix things.Foil doesn’t work in my experience. Numetal (something like that) will work, but it’s expensive.
If magnetic interference bothers you, get a 30″ apple cinema display to put beside your broadcast monitor. LCDs aren’t affected by magnetic interference from your broadcast monitor.
