Activity Forums VEGAS Pro Can Vegas pro edit multiple camera views at the same time?
  • Can Vegas pro edit multiple camera views at the same time?
    Posted by Tony Mazzorana on December 3, 2009 at 4:50 am
    I am looking to make Vegas my main editing system.
    I wanted to know if Vegas has a multi camera editing mode, where 2 or 3 different camera views can be mixed together with ease? If so, do you like it? How does it work?
    My current system has a feature called “Quadcam” and I can load up to 4 different camera views and edit all of them together as they play back in real time. All I do is watch my monitors and pick the view I want. It even allows me to go back and re-edit a cut that missed its mark by allowing me a 3 second leaway on either side of the clip. In other words, I can take the clip and extend it 3 additional seconds on either end to cover up a glick I missed and it remains insink.
    Thanks for your help.
    Adam Rose esq. replied 16 years, 9 months ago 4 Members · 4 Replies
  • Adam Rose esq.
    December 3, 2009 at 7:04 am
    yep. vegas has been able to do that for about 5 years (?) or so, at least.
    3 options:
    1) use the built-in tool
    2) use UltimateS plugin from https://www.vasst.com
    3) use Excalibur plugin from https://www.jetdv.com/excalibur/home.php
    Vasst also has a tool called infiniticam IIRC, which is simpler than UltimateS, ie is far less powerful
    The built-in tool is fast and effective, but the 2 main alternatives give you more flexibility. Can try them both on demo version
    here is an article on the cow of what was possible in vegas back in 2005: https://library.creativecow.net/articles/duncan_timothy/stellars.php
    10 cameras………. 🙂
  • Byron Kawane
    December 3, 2009 at 7:30 pm
    Can UltimateS and Excalibur handle multi-cam clips in diffrent formats like .avi and .mov at the same time. I know Vegas can’t. I have to re-render each clip to the same format then use the Vegas multi cam function. This works fine just takes time.
    Byron
  • Mike Kujbida
    December 3, 2009 at 8:18 pm
    [byron kawane] “Can UltimateS and Excalibur handle multi-cam clips in diffrent formats like .avi and .mov at the same time. I know Vegas can’t”
    Byron, I hate to say it but you’re mistaken.
    Vegas can do this quite easily as I’ve done it before and so have a lot of other users.
    If your computer can’t do it, then I’d be checking it out to see what’s wrong with it.
  • Adam Rose esq.
    December 3, 2009 at 8:22 pm
    Agreed with the Hon Mr Kujbida 🙂
    Just tried it, as hadn’t ever noticed a problem or heard of that before. Had .avi, .mov & mp4 in vegas multicam all playing quite happily.
