Activity Forums VEGAS Pro Can Vegas & DVA do this?
  • Can Vegas & DVA do this?
    Posted by Qivideo on March 7, 2006 at 4:59 pm
    I want to have a DVDA menu that is a video of a small, clear water river. I want to put in a still frame(s) that is transparent so it looks kinda like a ghost in the water. I have not found a way to do this. I tried setting the still as a “mask” in DVDA. With “intensity” turned on this looks like what I want. But when previewed or burned that doesn’t work. Any Ideas?
    Michael
    Phillyswiss replied 20 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Edward Troxel
    March 7, 2006 at 5:51 pm
    Do it in Vegas. Get it looking the way you want and render it out to DV-AVI. Now use THAT for the menu.
    Edward Troxel
    JETDV Scripts
  • Qivideo
    March 7, 2006 at 9:53 pm
    I do not see a way to do it. I can have a track with hte video and a track with the stills but how do I make the stills transparent merged with hte video?
    Michael
  • Edward Troxel
    March 7, 2006 at 9:56 pm
    I’m not exactly sure what effect you’re after. I’m guessing you would start by varying the opacity?
    Generally speaking, I would make whatever effects I wanted in the video in Vegas and then import that into DVDA for the menu. You can add “empty buttons” to use as links even if you put the link image or text into the background video.
    Edward Troxel
    JETDV Scripts
  • Adam Rose esq.
    March 7, 2006 at 10:32 pm
    try mucking around with the blending modes
    eg Screen, overlay etc, in the track header
    still in top track
    water in lower track
    might even find displacement map works well.
    track 1: still
    track 2: water
    track 3: same water again
    track 1 has displacement map with Track 2 as child
    something like that – just talking off the top of my head
  • Qivideo
    March 8, 2006 at 1:34 am
    Thanks for the replies.
    I did find that simply varying the opacity gave me what I was looking for. Looks like image is floating above the bottom of the stream.
    Michael
  • Peter Wright
    March 8, 2006 at 2:15 am
    You could also use height mapping to make the still look like it is riding the ripples in the water.
  • Phillyswiss
    March 8, 2006 at 6:46 pm
    qivideo
    can you email me at phillyswiss@hotmail.com
