Activity Forums VEGAS Pro Can Vegas 11 render with these specs?
  • Can Vegas 11 render with these specs?
    Posted by Paul Doss on December 29, 2012 at 5:57 pm
    Codecs: Apple ProRes 422 (HQ) [preferred], Avid DNxHD or DVCPro HD
    Color space: ITU-R BT.709
    Audio: Stereo LPCM in either Big Endian or Little Endian, 16-bit or 24-bit, at 48kH
    John Rofrano replied 13 years, 9 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    December 29, 2012 at 6:28 pm
    [Paul Doss] “Codecs: Apple ProRes 422 (HQ) [preferred], Avid DNxHD or DVCPro HD”
    You can render to Avid DNxHD but you need to download the codec from the Avid web site and make a custom template. I show you how in this tutorial on my web site:
    Create a QuickTime Avid DNxHD Render Template in Sony Vegas Pro
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Paul Doss
    December 29, 2012 at 7:53 pm
    Thank you very much John. Will the audio specs be as required? “Audio: Stereo LPCM in either Big Endian or Little Endian.”
  • John Rofrano
    December 29, 2012 at 8:41 pm
    [Paul Doss] “Thank you very much John. Will the audio specs be as required? “Audio: Stereo LPCM in either Big Endian or Little Endian.””
    Yes, the Uncompressed audio in my tutorial is LPCM and it will be encoded Little Endian by your Intel processor.
    ~jr
  • Paul Doss
    December 29, 2012 at 10:42 pm
    Many thanks John for all the info and great tutorial. I did a little test render with it but the play back doesn’t look very good on my computer.
    Very interesting bio on your site. Thanks again.
  • John Rofrano
    December 29, 2012 at 11:46 pm
    [Paul Doss] “I did a little test render with it but the play back doesn’t look very good on my computer. “
    If it doesn’t look good, you might want to increase the bitness. When you press the Configure button in step 4, use 1080i/59.94 DNxHD 220 8-bit or 1080i/59.94 DNxHD 220 10-bit instead of 1080i/59.94 DNxHD 145 8-bit. The files will get larger but the quality will improve significantly.
    ~jr
  • Paul Doss
    December 30, 2012 at 2:14 am
    I only see one option for 1080i/59.94.
  • John Rofrano
    December 30, 2012 at 11:05 am
    [Paul Doss] “I only see one option for 1080i/59.94.”
    You need to scroll up in the list to see the other two at the top:
    ~jr
