Activity › Forums › VEGAS Pro › Can veg backups go to another drive?
  • Can veg backups go to another drive?
    Posted by Larry Watts on September 26, 2008 at 4:40 pm
    I’d like the backup veg. files to go to another drive and folder than the main project folder. I cannot find a place to change this.
    Is there a way to do this?
    Vegas behaves a bit diffently on my new workstation. When I am dragging a selection area it used to snap and yellow highlight when it hits a marker. It no longer does so. If I select the marker it does snap and highlight. (My snap feature is on)
    Again, I cannot after searching, find the place to control this.
    Larry
    John Rofrano replied 18 years ago 2 Members · 1 Reply
  • John Rofrano
    September 26, 2008 at 6:26 pm
    The backup veg files cannot be changed from being placed in the same folder as the veg file. It’s just how it works. You can turn them off but you can’t change where they go. (Can’t say about the yellow highlight problem)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
