Activity Forums Adobe Premiere Pro Can uneven audio levels be reasonably fixed? Please…how?
  • Can uneven audio levels be reasonably fixed? Please…how?
    Posted by Bruce Pelley on April 16, 2013 at 1:10 am
    How do I fix very uneven audio with Premiere Pro – Can it be done?
    Source/Root Cause: Person I’m filming is speaking into a handheld mike while walking around so they of course can’t hold it perfectly steady, level and still in order to produce speech that is consistently even and uniform. Also, in addition, their voice fluctuates to a significant degree & alternates between soft and loud.
    Results in: Audio with a substantial dynamic range.
    Correction Requires: (because I don’t know any better) a number of hours manually dicing up the audio track and boosting the segments that are soft to the extent necessary or trying to salvage the clipped parts.
    That intensive process and concentrated effort is: wearing, time consuming, tedious and tests my patience.
    I figure there must be a better solution! Experimented with the audio tools but has been shut out thus far & haven’t solved the problem.
    What should I be doing so I can automatically lower the highs and boost the lows?
    All advice & suggestions welcome.
    Thank you.
    Bruce Pelley replied 13 years, 5 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    April 16, 2013 at 2:16 am
    Use a compressor effect (listed as part of the “dynamics” effect in Premiere). A compressor compresses the dynamic range of audio so it’ll squash the volume of the loud parts. This is used in conjunction with make up gain (raising the volume) so the volume seems more consistent.
    You may need to noise reduce because you’re also raising the noise floor.
    There are a ton of tutorials on the process on Youtube.
    You may still need to ride vocal levels a little and you may need some heavier duty repair for clipping and other issues like noise.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Bruce Pelley
    April 16, 2013 at 2:21 am
    Thanks for getting me started.
    Open to other options as well.
