Activity › Forums › Adobe After Effects Expressions › can u show me this one
  • Kunal Puri
    May 31, 2010 at 7:41 am
    Hey Oscar, if I understand you correctly you have a video file that contains audio and you’d like to create a volume meter that responds to the audio in the video layer right? If this is what you need to do then why don’t you just export the audio from your final edit as a WAV using an After Effects Custom Render and use the WAV file as detailed in the tutorial.
    All hail the cow!
  • Oscar Pettigrew
    June 1, 2010 at 3:30 pm
    will it be hard to line up the vocals after im done
    because if i put it in a wav file im going to have to line up the vocal with the video …?
  • Michael Szalapski
    June 2, 2010 at 3:47 pm
    If it’s from the same file, just line those layers up to each other.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
