Activity Forums VEGAS Pro Can u render quicker if some sections are already rendered ?
  • Can u render quicker if some sections are already rendered ?
    Posted by Francis Lee on December 3, 2019 at 9:29 pm
    I have a project with the same 30 second intro but many different 30 second endings.
    The 30 second intro is audio with 6 to 8 Generated Media Clips.
    The 30-second endings are customized for each occasion.
    Will it render faster if I render the 30-second intro first…
    Then put it back on the time line as a rendered clip
    Then add the 30-second ending sequences?
    Or, what is the best way to do this for quicker renders? I have about 100 of these to do.
    Thanks for any help.
    Wayne Waag replied 6 years, 9 months ago 2 Members · 1 Reply
  • Wayne Waag
    December 4, 2019 at 3:21 am
    If the first 30 secs is the same, I would suggest creating a loop region and then rendering to a lossless intermediate such as Magic YUV or UtVideo. You can use the built-in Render to New Track to create your intermediate. Depending upon the complexity of your 6 to 8 generated media clips, subsequent final renders may or not be a lot quicker. If they are very complex such as some of the HitFilm Fx, you can save quite a bit of time.
    wwaag
